Old 09-03-2011, 09:49 AM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
^ switch to mobil 1 0-20w Eco oil...i gained roughly 3-4mpg with that
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-05-2011, 09:59 PM   #2
digitalrain
Drives: 2011 yaris rs
Thanks for the tip on the 0w20 , I see that it's 48$ at the local place. I wonder if the payback is worth it on the incresaed MPG. Also if it reduces wear on the engine over the long run???
Really disappointed in the initial MPG so I took a drive Sat to loosen up the engine a bit and to see where the MPG would go with strictly highway driving.
2nd tank
516.6KM travelled
-31.56 L put in at pump 6.94 Can Gallons/8.33 US Gallons
-MPG 46.25 CAN/ 38.54 USIntangibles:
-moderately driven
-2% city/98% highway
-mountainous(Coquihalla highway)
-temperature from mid 70s
-a/c most of the time
3rd tank
449.5 KM travelled
-24.86 L put in at pump 5.47 Can Gallons/6.56 US Gallons
-MPG 51.15 CAN 42.57 USIntangibles:
-lightly driven
-100% highway
-mountainous( but going down more) elevation changes
-a/c .half the time
4th tank
426.7 KM travelled
-32.86 L put in at pump 7.23Can Gallons/8.67US Gallons
-MPG 36.67CAN 30.53USIntangibles:
-lightly driven
-100% city
-mostly flat-temperature from mid 70s
-a/c .half the time
The MPG is getting much closer to what I saw with the Echo. Thank good ness. I guess after about 5000 miles it'll be pretty much the best it'll get...
I notice a lot of wind noise coming at 120KPH from the front window area. It cuts down a lot when reducing to 100KPH. Wind resistance must be much higher.
digitalrain is offline   Reply With Quote
I can never fill my tank completely? yarisitis Fuel Economy Forum 9 12-05-2010 11:51 PM
fuelly - tank size CliffB General Yaris / Vitz Discussion 4 07-10-2010 08:44 PM
Filling up using spare gas tank. Yarimoto Fuel Economy Forum 5 08-19-2009 04:29 PM
Oil catch tank question window_lee General Yaris / Vitz Discussion 1 07-14-2009 08:04 AM
How many miles are you getting on a tank? TDL General Yaris / Vitz Discussion 1 11-29-2006 04:28 PM
