Old 09-05-2011, 02:40 PM   #1
CAyaris
CAyaris's Avatar
Drives: 2008 Toyota Yaris Sedan
Send a message via MSN to CAyaris
the endlink wont go from top to bottom and when it does the car cant turn with out snagging the brake line
108hp and still rolling
CAyaris is offline   Reply With Quote
Old 09-05-2011, 03:10 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I assume your car is on stands when you took that photo.
Mount your wheel back on the car, tighten the lug nuts enough so your wheel doesn't fall off. Lower your car with a jack on the frame so the tire rests on the ground. You can raise or lower the jack to get the endlink into that hole.
Old 09-05-2011, 08:06 PM   #3
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
stock: (from a thread on here)
The mounting hole apears to be about the same distance from the tube. ....but, the end link looks more straight up and down in your picture. Is it the stock sway bar?
The Coilover Thread Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 294 02-23-2025 01:20 PM
COilover help, choosing right one CAyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-25-2011 02:18 PM
coilover sleeves mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 07-25-2010 06:13 PM
Is it possible to add coilover sleeves to tokico blues with tein s-techs? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-22-2010 03:03 PM
D2 coilover deadcrow Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 05-10-2010 01:32 AM
