Old 09-06-2011, 05:33 PM   #1
nicorac
Drives: Yaris 2007
I've made a little step forward.
I measured the cell battery: 2.9v (ok, with no charge attached, anyway...)
I tried cleaning the button with contact cleaner: no way.
Then a lucky break: pressing the Unlock button twice really quick it worked, all of the times.
When I say really quick I mean really quick, say 2 presses in less than 0.3 seconds.
It seems some kind of security feature
nicorac is offline   Reply With Quote
Old 09-06-2011, 08:16 PM   #2
That would make me suspicious of the remote itself. Did you clean both the circuit board side and the rubber membrane side of the switch?
Old 09-08-2011, 11:02 AM   #3
nicorac
Drives: Yaris 2007
Sorry for the late reply.
Well, I used a spray cleaner (the one used in my electronic lab to deoxidate contacts), and I tried to put it deeply into the button.
Another thing that makes me think about a "software" issue is the following test.
I tried alternating a double-quick press to a single press, in a sequence like this:
XX--(3s pause)--X----XX----X----XX----X---- and so on.
The double clicks were all successful and all the single ones failed.
AFAIK a bad-contact issue should not be so regular, I expected that some of the single presses was successful, and/or some of the double ones fail.
I'll try to remove the remote battery and leave it unpowered for some time, then delete and re-register it. Who knows?
remote entry
2007 Yaris hatchback pre-wired for Cruise control? naeemishaq General Yaris / Vitz Discussion 5 11-15-2010 10:31 AM
