![]() Drives: 2009 Yaris RS 5 door Join Date: Dec 2008
Is this a fuse?
http://www.toyota-tech.eu/aimuploads...01%20190-1.pdf Do you know if the part (N) on page 7 of 35 is a fuse? I fried my fog light relay and have checked all the fuses and still can't get them to work. I was wondering if part (N) was a fried fuse and if I replaced it would it get my fogs back running. If that doesn't work I was planning to put in a new aftermarket relay system.
my new 2009 Yaris RS 5 door
#2 | |
yes it does have DTL.
Can you snap a picture of how you have things wired? You said that you "fried the relay". If you are asking if N is a fuse (where it is actually the relay), what relay did you actually "fry"?
I actually don't know what got fried. It's a 2009 RS with daytime lights. It is all stock pre-wired OEM fog lights. I tried to get the fogs to work with low or high beams on by cutting the 4 wire on the headlight stalk connector and splicing it to 13. That didn't work.The problem was that because of the 2009 RS model wires looked different in color from what you had posted. I tried touching the 4 wire to other pins to see if I could get it working that way and that's when something got fried. I checked all the fuses and they seem to be fine. Now I was wondering if I remove the part (N) could I test it to see if it is fried? Maybe if I replaced part (N) that would get my fogs and dashboard indicator to work again. If all else fails, I'm gonna wire up the fogs the old school way. I just better not forget to turn off my fogs. I will try to get a photo but I'm not sure how to post it here.
#6 | |
You can test the foglight relay with an ohm meter. One pair of terminals should be about 70 ohms and the other pair should be open (infinite resistance). The typical failure mode of a relay is for the coil to fail and in that case both sets of terminals would read as open.
How and can the relay (part N) be easily removed? If it does happen to be fried,would replacing it with a new one solve my non functioning fog lights and fog light indicator?
| Fitting Front Fog Lights OEM - Yaris 2007 3dr | weller | Cosmetic Modifications (Exterior/Interior) | 1 | 12-17-2009 12:29 PM |
| Need some help with Fog Lights on 09HB | Pikachu | DIY / Maintenance / Service | 1 | 07-06-2009 01:40 PM |
| Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) | Lafiro | Cosmetic Modifications (Exterior/Interior) | 2 | 06-12-2009 03:56 PM |
| My ebay fog lights and led interior light pics | Julz | Photo-Video-Media Gallery | 6 | 09-13-2007 10:41 AM |
| Disabled DRLs and Factory fog lights | DARKYARIS | DIY / Maintenance / Service | 21 | 05-01-2007 05:32 PM |
