^ My cabin noise is amplified by several things: 3" turbo-back exhaust, TRD motor mounts, gutted rear panels, no baack seat, etc. So 4000 rpm is LOUD in my car, might not be so much in a stock car.
Winding it up produces more noise in general.
Is first gear of any use anymore?
On the street, yes it's great. Drag racing, probably not.
LOL.. 2nd gear launch.. in a yaris.. ohh how i wish i were in your shoes
I'll try it out both ways on Thursday. Looks like we have a few people coming out.
Mr. 155 and climbing
I can't recall what the RPM is at 70 with a stock final drive?
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
2ZR swap. DO IT! Ask how!
Changing the 5th gear ratio from 0.815 to 0.725 puts the 70 mph RPM right around 3160. Not great, but closer to stock. The 5th gear is out of a C59 from an 03-ish Matrix/Vibe/Corolla. That particular C59 also has a 3.941 final drive, which is a little bit more aggressive without going whole hog. The thing that sucks about the C59 is that they normally run about $1.2k rebuilt, $600 broken.
Ok, made some progress on my gear swap project. A C56 can indeed be torn down without the Toyota SST kit.
Important tools to have (or at least what I used): * Bolt puller set * Bearing separator set * 3/8" drive breaker bar * deadblow hammer Replacing the bearings will require a few other automotive tools, but I haven't messed with that yet. Putting it back together is a very different story and will require access to a hydraulic press and either a very precise torque wrench (0-15 in-lb) or knowledge of the mechanics/physics/calculus to make a widget that will verify the pre-load torque on the differential. |
I think Art used a 2-ton press. About $150 from Harbor Freight.
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
The guy I helped change the gears(he busted one on an xB) just got a press from Harbor Freight like Garm said.It was not easy,but it was cold and rainy and I had never taken apart a tranny before like this so I was just the helper.No need for special tools short of bearing separator and bolt outs,other than that is basic tools
ha, a unicorn indeed!
We have access to several final drives now. plus the Kaaz 3-4-5 gear set as noted, which will be posted to our online store shortly. Not for the weak of heart!! WOOT!
Wait till Cranky starts running the numbers, his head should be spinning.
no kidding.
ok, so final drives: 3.7 stock, 4.0 (pricey), 4.2 (xB), 4.5 (pricey) all to be posted to the store. The 4.2 xB one will be offered as a kit with the drive, ring gear and ring bolts. (Shims must be purchased separately)
#15 | |||
4.5:1 = ?? There's also a TRD 4.733:1 from the Starlet/Truino that may or may not fit. |
impressive.. you guys are on it..
4.0 and 4.5 are brand new from Japan. [insert banana dance smiley here]
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
So, did you try this out on a dragstrip? What was your E.T? How much did you trim off of your previous best time?
| I got $50 to test drive | Cutie Pie #2 | Off-topic / Other Cars / Everything else Discussions | 6 | 02-23-2009 09:51 AM |
| mid pipe swap | shinlee | Performance Modifications | 0 | 02-09-2009 10:44 PM |
| final drive | rx100 | Performance Modifications | 2 | 08-21-2007 01:26 AM |
| Longest Test Drive? | lostmind | General Yaris / Vitz Discussion | 4 | 05-31-2007 05:20 PM |
