![]() Drives: 2011 3-Door Liftback Join Date: Sep 2011
If I lift up the front from the center lift point using a floor jack, and I want to put the front of the car on jack stands, where would I place the jack stands? Are there front side lift points, like the rear side lift points? Thanks!
You would have to put the jack stands where the jack points are on the pinch seam behind the front wheels.
They are actually meant to be supported by a slit block, like the top of the OEM jack, as opposed to being supported by the edge. Prior to getting my lift I would lift the car from the center point and use my old jack stands under the seams. My jack stands have narrow tops, so I couldn't use the slit hockey pucks that I use when jacking at the seams. There is a bit of paint chipping on my seams from my stands, but no signs of deformation. With my lift, I actually lift it by the four pinch seams, but my lift has 6x6 pads with 1/4" thick rubber, so the pressure is well distributed.
I've read that the suspension needs to be loaded when changing struts or other suspension work. Is there any safe place to place jack stands that loads the suspension, or do you just need ramps for that?
Edit: My secondary motive for this question is that jack stands at their normal positions are in the way of the belly pan I'm installing. Last edited by spookybathtub; 02-01-2015 at 05:04 PM. |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
| Yaris Crashed! | elsteverino889 | General Yaris / Vitz Discussion | 13 | 11-06-2006 02:59 AM |
