Old 09-23-2011, 08:38 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Yep, 24.5 x9 x 13 you are right. Looks like compound is what it is.... no choice (L8). No modification necessary except 20mm spacers with 0 camber to clear coilover springs. Im not sure on the wheel offset though. Launching at 4600rpm 2step , I think about 6psi. Just over 300whp Dyno Dynamics. http://www.jegs.com/i/Mickey-Thompso...oductId=746895
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 09-24-2011, 01:16 AM   #2
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Cheers for the info man! Although I don't think I would choose that slick profile as it seems too overkill, I think Garm slick profile are better although not sure if M/H or M/T though!
Also with your slicks I see you launch at 4600rpm, is it because your engine is at max torque on that range?
What about your launch rpm and boost Garm?
Parmas is offline   Reply With Quote
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 01:49 PM
Tein S-tech over Stock shocks daddz07 General Yaris / Vitz Discussion 0 08-10-2010 10:48 AM
Tein S-tech Springs with Stock shocks combination. daddz07 Performance Modifications 1 08-09-2010 03:45 PM
BOOK VALUE : month > month Hershey General Yaris / Vitz Discussion 4 07-05-2010 01:54 AM
