Vitz_RS
Drives: Toyota Vitz RS NCP91 Join Date: May 2009
Where is the coil packs please...the transistor has been check and inverse also still the power not coming in the third line ignition
The coil pack is the part on top of the spark plug. The transistor has probably not been checked, since that is a part on the circuit board inside of the ECM.
In event of the main ecu replacement, is there anything to do like programming or replace other ecu(transponder, abs etc.)
Is it a direct bolt on with same part number? I am reading the service manual and observed that it needs only to program the VIN which is optional I guess.. CTScott, any thoughts on this? |
#4 | |
Because he has the smart entry system, that system will need to be resynced with the new ECM (which requires the techstream tool to do).
| Connects2 UNI-IR Universal Infrared Steering Wheel Control Interface | rognewton | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 05-04-2011 09:42 AM |
| 3 Drive Throttle Contoller by NTD | Sabretooth | Performance Modifications | 31 | 10-07-2010 12:12 PM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
