09-30-2011, 11:43 PM
#1
Drives: Yaris Sedan "S"
Originally Posted by talnlnky
From Sqcomp to talnlnky:" Hey Taln, can you run a graph for the IDQ 12v3 D4? I'd really like to know what a pair of those in 1 cube each sealed with 750 Watts a piece would do..."
here's the frequency response, and cone displacement graphs... you'll well within the X-max, so distortion should be low. QTC of a 1cuft box per sub is .691, fairly low for a sealed setup.
Red line = 2cuft sealed (1cuft each) looks like usuable range down to 30hz.
Blue line = 10cuft sealed (to simulate what an IB setup might look like)
The IB can safely play about 5hz lower than the Sealed can, I don't know what the x-mech is on that sub, so its possible it could safely play much lower, but with added distortion.
That is my subwoofer an IDQ 12v3 D4 in a sealed box of 1 cu feet. and I can only say good things.
D.
.  My system may not blow your ears, but it will sweeten your senses.
CLA 250, 4MATIC
