![]() Drives: 2007 yaris hatchback Join Date: Mar 2007
Boo for 3 step Maguire's
My wife and I both have Yarises mine is blue hers is grey (yes, its so Masculine!). I busted my ass for about 3 hours (using an Orbital buffer for removal no less) and My car is shiny but wait hers is too and hers isn't waxed. I had a feeling as I went through each step that all I was doing was applying a more concentrated wax than the previous step. For this much work I could have used 3 coats of regular wax and have 3 times the protection. Because after all you can't make a stock Yaris paint job look like a custom 12 coat lacquer job no matter how awsome your wax is.
YRS WHOR
Drives: White 2007 Yaris E-Limited 5dr Join Date: Feb 2007
As you noted it's not a show car paint job, so of course you don't expect a show car result, BUT, what you should expect though is a very clean finish (as a result of step 1), enhanced depth of color (as a result of step 2), and a "wet" look to the finish (as a result of step 2 & 3).
Obviously you can't compare color-depth between different colored cars, but you should notice the following: 1. Look at the paint from a close distance (say a foot or so) - you should be able to see "into" the paint rather than just the paint surface - this is depth of color. 2. Look at the paint from yard or so and move your head around to view it from different light angles - it should look like it's "wet" Here's some personal recommendations/tips: Polish (i.e. step 2 - not the wax in step 3) should *always* be applied and removed by hand - the friction created by machines will generate too much heat and it just won't get into the finish. You should also not let polish dry - work in small sections applying the product slowly and methodically, then remove it by hand before it dries. This is also why you must always polish and wax in the shade, with cool paint - hot paint will dry out the polish before it can get into the finish. Normally I wouldn't recommend removing wax (step 3) with a machine either as it will almost certainly disrupt (or even totally kill if you get too much friction/heat happening) the polymer bonding process - this is especially true if you're not giving the wax time to bond overnight. Machines however are great for applying wax as you can get a nice thin, even layer of product down on the finish, which will in turn mean that hand removal is a snap. Polish gets into the finish, while wax bonds to the surface of the finish.. |
#3 | |
Drives: 2007 Yaris LB Join Date: Mar 2007
![]() ![]() ![]() Drives: Silver Hatchback Join Date: Jul 2006
silver always looks well maniucured, due to its nature its very hard to find flaws in it if your not looking
| Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 07:40 AM |
| Accessory Bulb Types, anyone know? | Ayka | Cosmetic Modifications (Exterior/Interior) | 135 | 04-29-2007 09:33 AM |
| Boo is in!! | Boo | New YARIS Purchase Forum | 21 | 08-23-2006 02:28 PM |
