advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
Some new goodies...Clutchmaster+light flywheel= WINNING
THE OLD:
Original equipment clutch and flywheel. Approx 470,000 miles!! ![]() ![]() ![]() ![]() THE NEW: Clutchmaster stage III clutch The FX300 System uses the Power Plus I Pressure Plate with a Steel Back Segmented Kevlar disc. This clutch is designed for the ultimate street enthusiast or weekend racer running a normally aspirated car equipped with cylinder head work and/or hotter cam(s), or with medium-boost turbo or super-charger, or up to 100hp NO2. The FX300 features only slightly increased pedal pressure, long life disc and positive engagement. Competition Clutch Lightweight flywheel SPECS: Forged steel remains in a solid state throughout the manufacturing process, maintaining a tighter grain structure resulting in higher performance loads. · Forging does not allow for porosity in castings and ensures a more reliable consistent material flow throughout the part. · Eliminates ring gear separation. · Eliminates friction surface and flywheel warpage. · One piece ring gear for high durability. · Stamped with 4140 forged plate with 2000 ton pressure at 1260 degrees. · CNC machined and balanced to OE specifications. · Meets and exceeds SFI 1.5 specifications. · The lightweight steel (heavier) version preserves low end torque and drivability. · All steel flywheels work with any performance and OE clutch assembly. ![]() Got this put in on Friday right after I picked it up from Jeff over at Micro Image. I can't say enough good things about this combination, the improvement is almost unbelievable...the closest thing I can compare it to(with my limited manual trans experience) is the clutch in my friends 2011 WRX. The grab is awesome, the clutch is smooth and easy to use in bumper to bumper traffic, my first drive on the new setup was from Glendale to San Diego(135 miles) @ 6PM...it took me an hour to go 20 miles, literally, and I didn't have any fatigue in my left leg! ![]() ![]() So far this mod has gained me the most noticeable improvement, I wish I would have done it sooner.
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
Local Sh*t Disturber
Drives: 2009 Yaris LB Join Date: Aug 2009
Damn you have that many miles on your Yari?
You think your Yaris is low and fitted LOLzzzzz |
advocatus diaboli
On everything but the engine, it was swapped out by the previous owner about 250K ago(estimated).
Wow!!! Thats awesome
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
Any difference in acceleration?
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
advocatus diaboli
Yes, although I'm still in te 500 mile break in period and haven't gotten to fully test it out I can already tell a difference thru all the gears. On the drive home I was able to accelerate nicely in 5th where I'd normally have to downshift to do so.
That old clutch has seen better day! Good thing you got this going before the turbo :)
#8 | |
advocatus diaboli
I can't believe how long that thing lasted...and it was still going. I grabbed that turbo because it was such a good deal, it's been torture pouring other money into the car, knowing I could be running a turbo for less than what I'm spending on something else. I need the car to be reliable, so I'm doing my best to get it ready to avoid any down time in the future. Each mod I've done has been for the better, so it's not like I don't get any enjoyment out of them....I'm just tired of making the blow off sound myself between shifts, people are starting to look at me funny.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| Intermittent low oil pressure light. | Inspector14 | DIY / Maintenance / Service | 23 | 03-29-2010 01:46 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
