Old 10-03-2011, 03:35 PM   #1
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
Engine buzz under load?
Since I am relatively new to Yaris and don't always know what's normal and what's not...
Whenever I accelerate, somewhere around 2000 rpm my engine sound changes. It gets this buzzy component to it. It's steady and is not a rattle or clank or tap-tap, just a steady buzz.
If I just rev up while standing the engine sound remains a consistent purr.
The car is 3 years old but very low mileage - 25000 km (~15000 miles).
Normal?
Thanks.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 10-03-2011, 04:09 PM   #2
A-Dingo-Ate-My-Baby
Drives: yaris
is it a hissing ?
a whining ?
a purring ?
a scraping ?
a squealing ?
a muffled whine/purr/scrape/buzz/squeal ?
a gear noise ?
a creak ?
a "nya, nya" ?
a "ohm, ohm, nya, nya"
or "who, whu, wuuu, wuuu" (Bubb Rubb)
Here are all the possible sounds:
Bad Bearing in Timing Belt Tensioner: woh woh woh woh
Boiling Coolant: bllgh blllgggh blllllgggghh
Brake Booster Failing: hissssssssss ssss ss
Clutch Release Bearing on the Way Out: jee je je jeee
Clutch Screech: screek, screek, screek
Connecting Rod that went through the Engine Block: clicketta clicketta clicketta
Dieseling: blubBLUBblubBLUB
Engine Knock: tuckaTHUCKtuckaTHUCKtucka
Engine Reving Up and Down: vooRRRR, vooRRR, vooRRR
Fly Wheel: gurrEENK, gurrEENK, gurrENK
Loose Belt: YEEeeEEeeEEeeEEeeEEee!
Low Coolant: bwwob bwwwobbubwub
Misfire: puhVRooPuhHoo puhVROOpuhHOO
Sticky Lifters: dicka, dicka, dicka, dicka
Water Pump: grrgula, grrgul,grrgula, vum wum wum wum wum
Weak Battery: wurrrrRRRRrrrrwuRRRrrr
Wiper Transmission Sound: eee eee eeee eeee
Vacuum Leak: vwishhhhhhhhhhhhhhhhhh
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 10-03-2011, 04:30 PM   #3
Kaykogi
Kaykogi's Avatar
Drives: 2009 Barcelona Red Sedan
Originally Posted by A-Dingo-Ate-My-Baby View Post
is it a hissing ?
a whining ?
a purring ?
a scraping ?
a squealing ?
a gear noise ?
a creak ?
a "nya, nya" ?
This is the best thing I have ever seen in my life.
Kaykogi is offline   Reply With Quote
Old 10-03-2011, 04:31 PM   #4
Kaykogi
Kaykogi's Avatar
Especially this one.
Old 10-03-2011, 04:18 PM   #5
Yury
Yury's Avatar
I'd say a constant muffled buzz. If I had the radio on at a reasonable level I would not notice it.
none of your sounds match really.
Old 10-03-2011, 04:23 PM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Maybe it's air wooshing past the throttle plate.
Old 10-03-2011, 04:43 PM   #7
Yury
Yury's Avatar
another thing that comes to mind is leafs rustling. but steady, no variation to it.
Old 10-04-2011, 11:39 AM   #8
Yury
Yury's Avatar
Just test drove a colleague's Echo. Found the same sound. It was less prominent but it was there. Her Echo sounds a little quieter altogether maybe that's why there was it was less.
Anyhow, I will chalk it up as normal for this engine.
Old 10-04-2011, 02:16 PM   #9
josh044
Drives: 07 yaris hb - 5 spd
I have the same thing on mine. I've never owned a car with a timing chain, and I don't think you're supposed to hear a timing chain, but this is how I'd describe it. It's what I think timing chain noise would sound like.
josh044 is offline   Reply With Quote
Old 10-04-2011, 02:24 PM   #10
Yury
Yury's Avatar
i've been thinking the same thing exactly.
Old 10-05-2011, 10:00 PM   #11
CoryM
Drives: 2009 5-door, 5-speed
The timing chain on my car is audible as well. It's a whirring noise that gets faster as engine rpm goes up. It sounds a lot like the whine of an alternator charging hard if you have ever heard that.
Cheers.
Cory
Old 10-05-2011, 10:35 PM   #12
Yury
Yury's Avatar
Cheers.
Cory
like in this video http://www.youtube.com/watch?v=FGGoHOjeVn4 starting аt sec 8? that sounds similar to my engine :)
Old 10-05-2011, 10:56 PM   #13
CoryM
No. Chains sound like this maxima. You can hear it most as the engine rpm is coming down after the throttle snap. A whine.
http://www.youtube.com/watch?v=paPZ-...eature=related
In his case the plastic the chain rubs against is worn or broken off the tensioner and is now on the metal so is louder than normal. Our yarii chains are a little noisy but seems normal.
Cheers.
Old 10-05-2011, 11:04 PM   #14
Yury
Yury's Avatar
Cheers.
so what am I hearing then...mine sounds much like in the link I posted, except that I have to be accelerating, not just revving.
EDIT: although I must say that the noises in these 2 videos are not that far apart tone wise, esp accounting for the variations of the recording equipment/environment
Old 10-06-2011, 12:28 PM   #15
Yury
Yury's Avatar
Dropped by a dealer this morning. They tightened up exhaust heat shields, but that didn't make much difference.
Also showed it to my mechanic. He pronounced it normal, and said that what I am hearing is a sound of the air intake. I drove around this this in my head and I agree that this sound may be described as air rushing in through a small opening. Psychology is a funny thing :)
He did mention that the intake design on these is 'tricky' (he said that in russian, but that's the best translation)
Old 10-13-2011, 12:06 AM   #16
TOLMACH
Drives: soarer
Yuriy,
I have the same sound.
What exactly did mechanic say about the intake? (I speak some Russian)
Pavel
Old 10-13-2011, 12:21 AM   #17
Yury
Yury's Avatar
Pavel,
He said "это нормально, я пытался разобраться и там интейк хитрый." Which is pretty close to my english translation :)
He said that 1.8 engines had the sound as well.
The more I drive it the more I hear this as whooshing air.
Also, look at the shape of the throttle body gasket:
I can totally see this mesh at the bottom making interesting noises and kinda concur with my mechanic.
Old 10-13-2011, 12:40 AM   #18
TOLMACH
Drives: soarer
Thanks ))
I have a 2 yo car with circa 40k on the odomoter and hear this strange sound as well. I am glad I found this thread cause my mechanical skills do not go beyond installing car speakers.
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Whining noise from engine bay when under load. rasper General Yaris / Vitz Discussion 2 05-07-2011 06:46 PM
