Old 10-03-2011, 10:44 PM   #11
thorasaurus
Drives: Charcoal '08 sedan
And back with more questions...
Okay, I've hit my first wall. I'm using the Black Widow 852 kit by the way in case it needs referenced. Install manual here (http://www.blackwidowsecurity.com/in...%20Install.pdf).
I'm not trying anything fancy, just running the wires straight to the actuators that came with the kit. I've tried connecting the common unlock wire (black/green) on the brain to the green wire on the actuator and the common lock wire (blue/black) on the brain to the blue wire on the actuator. The brain clicks and the horn honks (once for lock; twice for unlock) but the actuator doesn't move. I've tried every combination of the other two possible lock and unlock wires and even switch blue/green and the actuator won't move.
Any ideas? I only hooked up one for now because I wanted to make sure the wiring was right. Do I need to hook up the other three for them to work?
Thanks.
thorasaurus is offline   Reply With Quote
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 02:59 AM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 11:51 AM
The power upgrade thread ChinoCharles DIY / Maintenance / Service 19 09-27-2006 03:14 PM
