do you have a couple pieces of wire that you can test the bulb directly to the battery? Also compare the LED bulb to the original to make sure the nipple at the end is the at the same length.
Or with everything turned off, try and bend the little tab at the bottom of the socket up a bit. Maybe it isn't making contact. |
#2 | |
Little Eggy
Drives: Toyota Yaris Liftback 3DR 2009 Join Date: Apr 2010
#3 | |
Little Eggy
![]() Drives: 2007 Toyota Yaris 5-Door HB Join Date: Oct 2011
I say ditch the relay you bought too. It should work.
Little Eggy
Well when I tested my LED flashers in my rear tail lights ( they're aftermarket by the way).. without the relay and with the stock ones, they do the rapid flashing. But I ordered already the load resistors for the front ones, So we'll see if they will work. I'm just confused why my rear aftermarket tail lights works for those LED flashers but not for the front with my stock headlights.
| Tags |
| blinkers, flashers, led, turn signals |
| Turn Signal Wiring | petefozzy | DIY / Maintenance / Service | 6 | 01-14-2011 07:52 AM |
| Green 24 LED Turn Signals 7440 | fnkngrv | Cosmetic Modifications (Exterior/Interior) | 15 | 08-01-2010 11:04 PM |
| Turn signal audible alert | paultyler_82 | Performance Modifications | 7 | 10-01-2006 10:21 AM |
| Turn signal bulbs | casterqc | Cosmetic Modifications (Exterior/Interior) | 2 | 07-15-2006 07:44 PM |
