u should do a dyno before and after to see actual results.
![]() ![]() Drives: 2006 Yaris HB 5DR Join Date: Oct 2008
my yaris has not seen a dyno ever since I owned it!
![]() anyway, I think the result can be seen if one has a scangauge II / OBDII and the thing to watch is the air/fuel ratio (I may be wrong on this) . if the ECM is fooled by thinking it is getting a cooler air, it may allow a richer air fuel mix. theoretically, a liitle more fuel will give a little more power. our yaris have a knock sensor, I think that will prevent any predetonation in case I have too much fuel in. now, i have two problems: 1. I do not have the A/F gauges to see the results, i may have to rely on driver's instinct on this. 2. still I do not know which wire should i insert the variable resistor. |
| best performance mod for your $$$ | brycedudley | Performance Modifications | 56 | 10-16-2010 06:49 PM |
| Performance? | chrisj | Off-topic / Other Cars / Everything else Discussions | 9 | 10-16-2010 05:14 AM |
| Just Got A yaris: Performance Mod Suggestion | Marfulion | Performance Modifications | 23 | 03-09-2009 09:35 PM |
