Old 10-10-2011, 11:27 PM   #9
Revsson
Check out my remote start DIY for a location on the under dash fuse panel for +12. The spade terminal that I show in the guide is actually a location for a fusible link for an option that we don't get on this side of the globe. You can slide a 1/4" female spade terminal onto the supply side of the link position and then add an appropriately sized wire and fuse. The tap point is a 60A circuit, so you can safely add a 15 or 20 amp fused circuit to it.
http://www.yarisworld.com/forums/sho...ght=diy+remote
That voltage tap is a constant +12v, right?
So, if I wanted to tap into that for a GPS or something, I would have to remember to turn it off?
Is there a 60A fuse under the hood, in case something causes a high current draw?
FS/FT: Eclipse 3650 4 + 1 channel amp yaris2010RS Items for Sale by private party 3 03-11-2011 11:24 AM
Sub and amp for sale TEHxFALLEN V1.2 Items for Sale by private party 34 05-17-2010 09:06 AM
Help choosing sub Duckywitbigfeetz In Car Entertainment + Electronics (audio / video / alarm) 40 03-31-2010 12:06 PM
Quick advice needed on unfinished amp install GreenSpeed In Car Entertainment + Electronics (audio / video / alarm) 15 01-15-2009 11:03 PM
Connect mono amp. + subwoofer to stock HU? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 10-28-2008 10:01 PM
