2ZR swap. DO IT! Ask how!
What's the throttle body flange inner diameter? I've been thinking I want to try and fab up my own to get the full 1ZZ tb diameter instead of necking it down to stock.
#2 | |
![]() Drives: scion xb Join Date: Dec 2010
I think its a little bit more than 2.25". Huge response when going WOT. If you want to do it you'll have to make a custom flange since the throttle is 4 bolts instead of 3. |
Crap, I knew there was a catch! I thought there were some drive-by-wire TBs with three bolts, but looks like only the cable driven ones have 3. Does it look like the end of the plenum could be cut off and re-welded with a new flange? The only pic I could find online was a side view that doesn't show the TB port.
#4 | |
Yes you could cut were the throttle is bolted on and make a flange for the other throttle and weld it. It has the space to do it! Or you could use the throttle that comes with the manifold which is bigger than the 1nz. |
The yaris uses electric throttle control (DBW), not a cable like the xB. There are plenty of 1.8L throttle bodies for the 4-bolt pattern with DBW, but none that I can find with the 3-bolt pattern and DBW.
I see, well then you have to make a flange from 3 bolts to 4 bolts like I did. If you look at my first picture look at the spacer between my manifold and throttle. You'll need to make a flange that bolts to the 3 bolts of the manifold and on the opposite side of the flange put 4 studs(symmetrical to the throttle) in which you will bolt the new throttle. Wish I had the pictures of the flange so I can show you, but its pretty easy and I can to help you out with questions If you are going to do that.
#7 | |
Edit: I just picked up a manifold yesterday, and ordered a TB last night. The only thing I need to get this project rolling is the dimensions and layout of the cylinder head flange. Do you by chance know if the cylinder spacing is the same on the 1NZ and the 1ZZ? Last edited by CrankyOldMan; 10-14-2011 at 07:43 AM. |
| Custom Short Ram Air Intake Problem | laxsaint99 | DIY / Maintenance / Service | 10 | 04-27-2011 01:28 AM |
| Custom Intake manifold/w 1zz tb / direct port nitrous | blacksandiegovitz | Items for Sale by private party | 28 | 11-23-2010 08:57 PM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| My Custom Intake | RacerFreakXXX | DIY / Maintenance / Service | 7 | 12-21-2008 07:32 PM |
