2ZR swap. DO IT! Ask how!
The yaris uses electric throttle control (DBW), not a cable like the xB. There are plenty of 1.8L throttle bodies for the 4-bolt pattern with DBW, but none that I can find with the 3-bolt pattern and DBW.
![]() Drives: scion xb Join Date: Dec 2010
I see, well then you have to make a flange from 3 bolts to 4 bolts like I did. If you look at my first picture look at the spacer between my manifold and throttle. You'll need to make a flange that bolts to the 3 bolts of the manifold and on the opposite side of the flange put 4 studs(symmetrical to the throttle) in which you will bolt the new throttle. Wish I had the pictures of the flange so I can show you, but its pretty easy and I can to help you out with questions If you are going to do that.
#3 | |
Edit: I just picked up a manifold yesterday, and ordered a TB last night. The only thing I need to get this project rolling is the dimensions and layout of the cylinder head flange. Do you by chance know if the cylinder spacing is the same on the 1NZ and the 1ZZ? Last edited by CrankyOldMan; 10-14-2011 at 07:43 AM. |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
Monchy huevon t dije q brega!!!!
Here's on a friends Yaris N/A 115whp ![]() Here's on a friends Yaris Turbo/Nos 305whp
I Drive a 129whp Yaris ;) |
| Custom Short Ram Air Intake Problem | laxsaint99 | DIY / Maintenance / Service | 10 | 04-27-2011 01:28 AM |
| Custom Intake manifold/w 1zz tb / direct port nitrous | blacksandiegovitz | Items for Sale by private party | 28 | 11-23-2010 08:57 PM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| My Custom Intake | RacerFreakXXX | DIY / Maintenance / Service | 7 | 12-21-2008 07:32 PM |
