Old 10-13-2011, 12:41 PM   #1
nisyota
do you think the tighter it is the noise will still be present???
nisyota is offline   Reply With Quote
Old 10-13-2011, 04:36 PM   #2
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
If the belt is showing wear, it won't matter how tight it is, it will still squeak and need to be replaced.
Also, if you overtighten, you can throw the water pump bearing. And in that case it just would have been better buying a new belt.
NZ-FE Vios is offline   Reply With Quote
belt
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 01:58 PM
squeaky belt TickleTimeTim DIY / Maintenance / Service 14 03-16-2011 11:49 PM
Altenator Belt Broken After Replaced by Toyota Yaris_guy DIY / Maintenance / Service 12 01-18-2011 09:14 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
