Old 10-14-2011, 07:46 PM   #1
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
The problem is not with the relay, it is the New Led Bulb's you are trying to use
LED are polarity postive the normal front turn signal bulbs are not .
Simple solution change the wires around on the front bulbs and plug your LEd's in and they will work fine .
Oh and you must use a LEd relay to stop hyper blink
Old 10-14-2011, 08:19 PM   #2
joeljcruz86
Little Eggy
joeljcruz86's Avatar
Drives: Toyota Yaris Liftback 3DR 2009
Send a message via AIM to joeljcruz86
Well the end of the bulbs are the same as the new LED bulbs. Its a solid with the "nipple" at the end. so there isn't any visible wires like the wedge bulbs.
joeljcruz86 is offline   Reply With Quote
Old 10-14-2011, 09:42 PM   #3
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
reverse the wires on the bulb holder ie swap them around , that is what i had to do
Old 10-15-2011, 12:39 AM   #4
joeljcruz86
Little Eggy
Yes they work! Unfortunately I have now the pair of Load Resistors that aren't being used. I e-mailed the company seeing if I could get a refund and return them. They're only $12
blinkers, flashers, led, turn signals
Turn Signal Wiring petefozzy DIY / Maintenance / Service 6 01-14-2011 07:52 AM
Green 24 LED Turn Signals 7440 fnkngrv Cosmetic Modifications (Exterior/Interior) 15 08-01-2010 11:04 PM
Turn signal audible alert paultyler_82 Performance Modifications 7 10-01-2006 10:21 AM
Turn signal bulbs casterqc Cosmetic Modifications (Exterior/Interior) 2 07-15-2006 07:44 PM
