Old 10-20-2011, 05:26 PM   #1
Do you have a sedan or liftback? The sedan's radio is built into the rear window, so if interior detailing was done, the cable that connects to the glass may have been ripped loose. If it is a lift back, like Klink mentioned, check to see that the antenna is still up top.
Also, was the dash taken apart at all?
Old 10-20-2011, 06:05 PM   #2
Revsson
CTScott meant to say that the sedan's radio antenna is built into the
rear window. But you probably figured that out.
If you lost the saved radio stations, does that mean that they
disconnected the battery? Did the body work require that they remove the battery?
What kind of body work was done to your car? Was the radio working properly
after the body work and before the detailing, or was the detailing just after
they did the body work?
If you look at this section from the factory repair manual, you will see the
route that the antenna cabling takes.
http://www.etimago.com/yaris/repairm...o%20Visual.pdf
Just wondering if the body work was done on the areas that the cabling
is running through?
Perhaps you can give us more information?
radio, scratchy
Car Buying Scams nemelek Off-topic / Other Cars / Everything else Discussions 1 09-29-2011 08:01 PM
KCALB SIRAY - Photo Scavenger Hunt KCALB SIRAY Photo-Video-Media Gallery 5 03-02-2009 10:44 AM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-01-2009 11:12 PM
Darb - Photo Scavenger Hunt Darb Photo-Video-Media Gallery 3 03-01-2009 09:02 PM
