Old 03-09-2007, 10:13 PM   #1
ChinoCharles
Drives: LB
This is my call to the wiring boys on this site. You know who you are.
STEP ONE: Buy two of these in the proper length.
http://www.oznium.com/led-flex-strips
STEP TWO: Mount them in the tail light housing in the JDM tail LED position.
STEP THREE: Wire them to the stock brake light assembly.
STEP FOUR: Write a DIY.
Old 03-10-2007, 08:05 AM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Wouldn't work. You need running lights that get brighter when you hit the brakes. The easiest way to do that would be to use one of the numerous LED lights that you see on tractor trailers nowadays. Take your stock tails apart, mount the trailer light in there and wire to a stock light bulb base for easy plug in. Or you could get some Lumined LEDs & resistors and solder up your own.
There's a whole community doing this type of stuff: http://www.hidplanet.com/forums/view...8c2573890494bc
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
RS LED TAIL LIGHTS jimcat Cosmetic Modifications (Exterior/Interior) 11 12-01-2006 11:20 AM
blinking LED light kaymm In Car Entertainment + Electronics (audio / video / alarm) 3 09-14-2006 10:05 PM
