Old 10-21-2011, 02:25 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
As I mentioned in your other thread - There is no relay! The AC ECU drives the compressor clutch via a FET within the AC ECU.
so me not getting power on the compressor maybe sensor issue then.. 3 guys in toyota cant figure it out but they did check the ac fluid was full cant do compression check without the compressor spinning...
Old 10-21-2011, 02:29 PM   #2
Did they actually plug the TechStream tool in and see what the AC ECU has to say?
Old 10-21-2011, 02:30 PM   #3
marcus
toyota
marcus's Avatar
they wont do it unless the a/c button is blinking..which is not. would an obd reader give me a code i think my frind has one..
Old 10-21-2011, 02:37 PM   #4
Only a TechStream will communicate with it. A regular OBDII scan tool doesn't have the protocol info for the Toyota specific diags.
There is no flashing error light mode for the AC. I know first hand, as I have and AC ECU running on my test bench that I talk to with my TechStream tool and my YarGauge. It has about 6 DTCs logged, since it has power and CAN comm connections and the only sensor connected is the ambient temp sensor.
Do you have another dealer you can work with, since it seems like the service people at this one don't have a clue as to what they are doing.
Old 10-21-2011, 02:39 PM   #5
marcus
toyota
marcus's Avatar
ok ill try that......thanks
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
3 Drive Throttle Contoller by NTD Sabretooth Performance Modifications 31 10-07-2010 12:12 PM
2006 Yaris Hatchback Replacing Stereo Head Unit help lauren24 In Car Entertainment + Electronics (audio / video / alarm) 11 07-01-2010 11:13 PM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
