pimp and his friend did it themselves. I had my bottom end built by someone else.
![]() ![]() ![]() Drives: toyota yaris Join Date: Jan 2007
Finally got my car from the tow company Sunday I shall start stripping down my car! Find out wat actually happened to my engine!
Would everyone agree that my engine has been damaged from a bad tune? If it's only on 8psi with engine damaged tune seems to be the problem!
I know this is kinda far fetched.. but If it you had the money, when ever a check engine light comes on, the ecu will take snap shots of (correct me if im wrong) 10 seconds before the CEL came on and after. So you can see what ALL the sensors was reading when your engine blew up. Ex, oil pressure drop, fuel mixtures, knocks/pings.
only reason i say this is pure curiousity.. At lexus, we could see what happend and what RPM, engine temp, etc. the CEL took place and try to duplicate it. Like I said. It's a long shot and would prob have to pay for a tow truck and pay a diag fee.. They can use thier laptop TechStream tool and print out a copy for you
#4 | |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
C'est la vie
Building the engine yourself is certainly possible, but I wouldn't call it easy. I was lucky to have a friend with some experience with a few engine builds under his belt to help out with checking piston ring end gaps and assembling crank main caps just right. I also worked as a dealer mechanic for about 12 years. Although I installed many engines in that time and also removed many cylinder heads, I never rebuilt a lower end or short block. I am pretty sure I could pull it off this build by myself now but if I didnt have the helpful tips I got I may have just dropped the short block off at a "known good" engine builder.
Good luck whatever path U choose |
#6 | ||
thanks for ur advice! greatly apprepicated looking around and thinking all options avaliable
#7 | |
Anywho.. good luck on your build.
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
speaking of a good know engine builder, is Ptuning the only company that offers a bottom end build for the 1NZ-FE?
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
^ Nope. We can get that done for you. My car is a great example of a reliable, well-built result.
Ptuning has a great rep as well, and might be geographically more desirable.
yea but if I send it to Cali to get done then I get to bug you more :D ;) don't worry wont be soon but I'm starting to plan it more and more, now to give the wife some money for her down payment on a new 5.0 then I can reinvest money into another Yaris+build
Okay started pulling it apart haven't got the engine out but found a huge crack under the 4 cylinder smashed so bad hit my turbo piping made dents and small hole! Also have a major crack near the starter motor! Hopefully have the engine out and disassembled soon!! I will post photos tomorrow of the progress
Still umsure about my rebuild tho
#12 | |
C'est la vie
+infinity
![]() ![]() Drives: Axio GT Join Date: Apr 2012
As above,pictures will be a boost for us.
Who can spot the Problem!? ahah
well i have finally got time for my car just need a engine hoist to take it out then ordered nesscairy parts to put it all back together again! my 4th cylinder was the problem seems rod broke made holes everywhere front bottom and back has holes! not sure about the top! i am sure u can see it in the pictures!
whoa. OUCH
looks like you may have spilled some oil a tad bit there.
:D
Well engine is ready to be hauled out just need to buy an engine jack! Gram u will be hearing from me about parts
My plan is I am not gonna forged my internals I am going to get a stock engine change my clutch to the clutch master get new injectors I feel my cars injectors are maxing out and leaning out which bad if I can eliminate as many possibilities as possible hopefully I find where in my tune is the problem! Planning on get a boost controller so during the week I will run very low psi around 4! So I can take some stress of the engine! Running a car at extremely low psi or no psi is that sufficient air flow into the engine? Someone said they had to retard their timing map so they could get the car to go Redline! Btw just some fuked up news the company who tuned my car has closed down and being auctioned off!!
| List of Boosted Yarisworld Members | whooppee777 | Forced Induction Forum | 262 | 11-23-2022 05:49 AM |
| Boosted Yaris Quarter Mile Times | 1.5 | Forced Induction Forum | 0 | 01-03-2010 05:49 PM |
| Yari Boosted, Enge lite... | N3misiS | Forced Induction Forum | 14 | 11-20-2009 07:22 AM |
| Going Boosted | FryGuy | Forced Induction Forum | 53 | 03-01-2009 10:01 PM |
| PE Boosted Yaris Video | jinxor | Forced Induction Forum | 16 | 02-06-2009 02:33 AM |
