Old 10-28-2011, 10:40 PM   #1
enviri
enviri's Avatar
Drives: 2010 Yaris
More stolen parts from an XD!
First I did the side mirror mod from an XD...
Now..
Project cheapass BBK! (275mm vs 255mm, larger caliper/pads)
*This was months of research and self doubting to reality!
Scion XD/09 Corolla/Matrix Calipers USED: ~100$ off ebay; ~165$ on rock auto (semi-loaded caliper)
(toyo part# 47730‑12A10|47731‑12A10
06/2007-SCION XD - ZSP110 47-05: FRONT DISC BRAKE CALIPER & DUST COVER
12/2007-TOYOTA COROLLA -ZRE142 47-05: FRONT DISC BRAKE CALIPER & DUST COVER)
2012 Yaris SE rotors (toyota part# 43512-52130): ~105$ ea (msrp)
Napa Adaptive ONE pads w/ shims for Scion XD: 57$ (cheaper than buying shims and pad seperately, plus these pads are very HQ)
we're going to re-use the clips off the yaris' caliper. They are the same part #.
(optional) Steel brake lines off MI: 140$
=$322-$407 (or $462-$517 with brake lines)
Me and a buddy did a test fit just now, and everything fits fine.
modifications needed:
NONE!
**These are tested, no issue at all, ABS works, TCS works.
**funny how toyota accommodated the 275mm rotors with the dust cover lol. It now looks how it should be. The Euro TS/SR and JDM RS share the same dust cover.
Old 10-28-2011, 10:49 PM   #2
ASG14
Camry Owner
Drives: '96 Camry XLE 1MZ-FE
Send a message via AIM to ASG14 Send a message via MSN to ASG14
DING BRAKES ARE DONE
Oh, my '96 Camry. Who wants a braking competition?
ASG14 is offline   Reply With Quote
Old 03-04-2012, 11:51 AM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
I will take you up on that :)
I just did an BBK using OE parts as well
stock fronts were 288, I found 325mm off an A6
stock rears were 245, I found 300mm A4 Conv
cool thing was I got to keep my calipers, only had to replace rotors and caliper brackets, and I threw a fresh set of Euro spec pads
Old 10-28-2011, 10:52 PM   #4
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
niCCCEEEEEEEE
Old 10-28-2011, 11:25 PM   #5
Nice find! Have you tried triggering the ABS to see how it behaves with the bigger discs?
Old 10-28-2011, 11:27 PM   #6
ASG14
Camry Owner
He's not driving with it right now as he;s goign to paint the calipers.
But ABS should be fine.
Old 10-28-2011, 11:40 PM   #7
Klink10
Klink10's Avatar
Very nice. No relocation of brake lines?
Old 10-29-2011, 12:54 AM   #8
enviri
enviri's Avatar
Drives: 2010 Yaris
brake lines will stay. scion xd and yaris brake lines are identical.
here's more comparison shots.
Old 10-29-2011, 01:00 AM   #9
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
wait so lemme get this straight....to have rear disk breaks alls I'd have 2 do is steal 'em of a xD? I thought all scoins were 5 lugs
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 10-29-2011, 01:03 AM   #10
enviri
enviri's Avatar
Drives: 2010 Yaris
im not doing rears. yet. these are for the fronts.
Old 10-29-2011, 01:07 AM   #11
Qmobile
Qmobile's Avatar
o i see miss understood
Old 10-29-2011, 10:07 AM   #12
Klink10
Klink10's Avatar
^^^^Ditto
Old 10-29-2011, 04:18 AM   #13
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
Hell yes
weedtank is offline   Reply With Quote
Old 10-29-2011, 08:41 AM   #14
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
these will clear the stock wheels??
Old 10-29-2011, 10:31 AM   #15
enviri
enviri's Avatar
Drives: 2010 Yaris
you know..i forgot to bring my OEM 15" alloys last night..lol. it SHOULD fit. as there are scion XDs around with aftermarket 15s around..
Old 10-29-2011, 11:08 AM   #16
ROCKLAND TOYOTA
TRIM HUNTER
as i was doing my winter tire swap this morning I was checking clearance.....
Old 10-29-2011, 01:36 PM   #17
ASG14
Camry Owner
Andy, my Camry has 275mm rotors and 15" OEM steelies work fine. the ONLY concern would be the caliper clearence on the front of the rim, but I'd think it;s be fine. Let me know if you want the rotors since it doesn't fit my AE101.
Old 10-29-2011, 02:22 PM   #18
Say, that's nice. Will be spot on with painted calipers. Almost makes me want to give up my current 14" OEM steelie winter setup.
Gonna get yourself an xD donut, or do you have triple A in case of a front flat?
bbk, big brake, big break kit, brakes, jdm
07 YARIS Liftback FOR PARTS benjomothians DIY / Maintenance / Service 0 03-28-2011 02:10 PM
Aftermarket parts and Factory Warranty in Canada? jonathanq Canada 3 07-11-2009 01:17 PM
FS: C-One Parts new & used - Socal 03Z33 Items for Sale by private party 90 06-03-2009 11:08 AM
