Old 10-30-2011, 12:10 PM   #1
Hamster
Hamster's Avatar
Drives: 2009 5-Door Liftback
My advice is to forget you have antilock brakes and pump the brake pedal carefully as you normally would. That is exactly counter to the manufacturers advice (which is slam on the brakes for all they are worth)
I agree with this 100 percent, and I've likewise discovered that it's better to just pump the brakes if you find yourself in a slide. This is the first car I've ever driven that has ABS, and I fail to see how it's safer.
Hamster is offline   Reply With Quote
Old 11-16-2011, 12:09 AM   #2
Viperoni
Drives: 2005 Toyota Echo
This is terrible advice.
If you stand on the brake pedal, the ABS is kicking in constantly many times a second.
If you pump the brake pedal, ABS only kicks in when you're apply pressure.
When you're not applying pressure, ABS is not unlocking the wheels because there's no braking pressure, because they're not braking.
So you're going from many pulsations per second, second after consequtive second, to many pulsations for every alternating 1/4 second at best.
Even though ABS isn't the fastest way to stop a car in deep snow, not stepping on the brake pedal is far wosre.
Winter tires FTW.
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 11-16-2011, 07:51 AM   #3
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
Originally Posted by Viperoni View Post
Winter tires FTW.
ITS under 40 degree tires!!! GET IT RIGHT....
Old 11-16-2011, 11:55 PM   #4
Viperoni
Although you're technically right, it's semantics to the general population.
Old 11-17-2011, 08:20 AM   #5
ROCKLAND TOYOTA
TRIM HUNTER
I just LOVE busting BARBER'S balls thats all....
what snow tires good for Yaris Hatchback. opor24 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-28-2009 12:53 AM
HELP!? HORRIBLE drive home during first REAL Snow in Michigan, paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 12-11-2009 08:07 PM
Floor Mats 4 Aussie Yaris (right hand drive) wanted! YesHapiness Cosmetic Modifications (Exterior/Interior) 6 02-12-2007 07:29 AM
