Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 10-31-2011, 04:36 AM   #1
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Q: naka iridium na ba itong Yaris natin from the production line?
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 10-31-2011, 04:53 AM   #2
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
as far as my 2008 yaris is concern, hindi sya naka iridium..
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 10-31-2011, 05:27 AM   #3
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
nope, OEM denso plugs lang
syntax is offline   Reply With Quote
Old 11-01-2011, 02:13 AM   #4
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Tol nung nagpalit ako ng spark plugs, NGK yung nakita kong nakalagay tapos Denso na yung pinalit ko.. no fulus yet for iridium plugs.
rye7jen is offline   Reply With Quote
Old 11-01-2011, 02:35 AM   #5
syntax
syntax's Avatar
nye malish NGK pala ung nakalagay.. nagpalit ka na ng sparkplugs rye?
Old 11-01-2011, 02:50 AM   #6
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Oo tol, mejo may katok minsan sa starting eh, tapos mag-2 years na rin mga plugs ko kaya pinalitan ko na, si gian na tumira. Try ko picturan yung old spark plugs, mejo malayo na nga ang gap dun sa lead ba yun? ngaun parang bago ulit yung response ng engine. kung mapapansin niyo nung bagong kuha niyo ang yaris niyo, pagpasok ng primera tapos clutch papuntang segunda eh parang nahuhuli yung clutch natin? ewan ko mahirap explain, pero parang ganun yung feeling ulit nung napalitan na ng bagong SP. nilinisan na rin namin ni gian yung throttle kasi bumaba ng 400RPM ang idle, ngayon back to normal na ulit..
RPM at 60 mph 5 speed manual mark schofield DIY / Maintenance / Service 13 10-08-2011 12:14 AM
Vitz 2001 1.0 manual rpm diesel2901 DIY / Maintenance / Service 4 09-23-2011 12:02 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
