Old 11-04-2011, 09:44 AM   #1
barryware
It is not your suspension. It is your brakes.
Remove the drums, lubricate the sections of the shoes where they slide on the back plate as well as the pin at the very bottom opposite the brake cylinder (cylinder on top @ 12:00, one single large pin on the bottom @ 6:00). The pin is a large (1/2" diameter maybe??) which both shoes "pivot" on.
You may want to blow the dust off the springs and give them a shot of dry lube also.
If you let it get worse, you will be able to hear the "squeak" when you take your foot off the brake pedal and the shoes retract.
barryware is offline   Reply With Quote
Old 11-04-2011, 10:06 AM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
this is also possible... but considering its a 2011..., if your not that mechanicaly inclined, and dont have a spare car to use, I would get someone else to do this.
Depending on the miles, is it under 40k still? I would say this is a warranty issue also.. take it to the dealership and have a service writer ride with you to confirm the noise. If they agree that there is an issue, then they should take care of it.
If it is the brakes, let the toyota guys get thier hands dirty and save you the headache
-Derrick-
Old 11-04-2011, 02:25 PM   #3
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
In my case, it's not the brakes...I know the difference between the two, and I've already fixed the brake noise on mine(for the time being).
OP, don't go taking your brakes apart just yet...
-Type 07 FFL-
My odometer 03/11
Old 11-04-2011, 03:26 PM   #4
barryware
Well.. neither of us can "hear" the noise so it impresses me that you can tell the difference. Based on the description of the noise, actually the events that trigger the noise were exactly my symptoms and it was my brakes. I took nothing apart aside from wheel and drum removal. I just lubricated the contact points where the shoes slide on the back plate, the pin, and cleaned and lubricated the springs... Noise all gone. However, about 8k miles later, I can hear it starting again. Mostly during (after) a hard stop.
The noise happens after the stop (split second), when the vehicle wants to roll backward while the brakes are engaged and the shoes shift.
However as mentioned.. New car (2011) still under warranty, take it in.
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
NSW Proposed Suspension Restrictions Bella Australia 0 09-22-2010 01:51 AM
My suspension setup: Breakfast Blend for the angry panda Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 07-26-2010 03:56 PM
Tein Basic Compact Suspension for SALE!! 33lam Australia 14 04-17-2010 08:24 PM
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
