Originally Posted by charlieXX
Mga kayaris pa-guide naman po
Will this work and fit our 2NZ engines??
http://shop.microimageonline.com/aFe...L-51-11302.htm
Or do you have something locally available, mas type ko itong ganito na nasa ibabaw lang tulad din nung ke @duke how much budget sa ganito mga bro locally na??
C, YES- bolt-on to 1.3L 2nz yaris. ganyan na ganyan yung intake kit ko dati at namana na ngayon ni blessed yaris. Nasa $200+ pa nun ang bili ko from ebay. Ang advantage nito is easy to fit and easy to remove as the design is plug and play.
Kung locally made naman or diy, maraming options..either via PVC tee pipe mod (like exweber/syntax) or via coupling with aluminum tube using the OE MAF mount. I prefer na you score OE maf mount + tube from a junk yaris. Keeping your original behind the trunk and you can put it back during rainy days or sandstorm season.
HiH
