![]() ![]() ![]() Drives: 2016 Yaris 3 Dr Super White Join Date: Mar 2016
#3 | |
Drives: 2016 Toyota Yaris L Join Date: Aug 2018
2016 Toyota Yaris L base model Automatic Touchscreen No steering wheel controls ? |
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback Join Date: Jul 2016
Your dealer person is crabby apparently. The dealer I bought my 2016 Yaris L from actually gave me the clutch switch and installed it for me after I showed them I plugged in the factory switch from another car into the steering wheel and that it lit up on the dash. The service adviser wanted to see if it would actually work hahaha.
-Karl the Uber/Lyft Driver |
I remember that! That’s why I wouldn’t give up, I know it’s been done before. My dealer deals with a lot of little old ladies buying Corolla’s, Camry’s, and Rav4’s. They just sell the higher package and could care less about modding.
I hope CTScott is well.
Is he not ok? I haven’t seen him on here in awhile.
He's been on, just not posting.
![]() Drives: Yaris MK2 Join Date: Jan 2016
I've just installed the cruise control stalk into my 2012 Yaris with a 1.3 (2NZ) engine. Its automatic and GCC (middle east) spec. Straight plug and play into the 4 pin connector slot which was empty next to the 10 pin connector. Mine has audio buttons as well bluetooth handset buttons. I didn't have to swap any pins whatsoever, cruise light and set all work fine.
Took about 10 minutes including setting up the audio after battery disconnect. Only thing remaining is for the oem cover with the hole and rubber grommet to arrive. Thanks to CTScott for all the info in this thread ! |
Hello I´m new at forum,I want to now if my Toyota Yaris is ok for cruise control
the picture is from under the steering next to yellow socket,the 10 pin socket and if I can buy a set from you Scot Last edited by Per Olof; 07-28-2018 at 02:07 AM. |
scot does not sell sets he is not a dealer. you can buy all the parts from the internet. on camelback. he just assembles things.
thank you for your ansver,I have look at Rostra and conection to ECM is not possible
Its a diffrent ECM behind the glove compartment,But I found a good universal one at CANM8 England,It works fine in my car from OBD and can bus,the only thing is that it dont get brake signal to can bus, but they send me extra conection from the brake padel to cruise module,I have test it already and it works fine without extra adjustment,it has a cruise brake butten on the backside of the stulk |
![]() Drives: Yaris 2012 1.0 5 doors Join Date: Feb 2012
Dear Friends!
Tell me known yaris 5 doors hatchback 2012 with 1.0 european version spain KSP90L-CHMRKW can be to installed CCS ? Thanks a lot! |
![]() Drives: 2007 Yaris Join Date: Jun 2018
Hi everyone,
I have a US Model, 07, M/T, 1.5L, 3 door hatch. I'm installing this CC solution and I'm at the point where I'm running the D3 connector to the ECM pin 40. Please see the pic below. Which wire and pin do I send to the ECM and which one do I ground? The picture of my Yaris is different then the pictures in the instructions from CTScott. Thanks!! https://share.icloud.com/photos/04lH...ah7sf_DqrWtH0A |
#16 | |
![]() Drives: Yaris 1.3 europe Join Date: Oct 2018
Hi
I have yaris 2013 1nr-fe 1.33 engine europe specs and installed the cruise stalk . The problem is the indicator at the instrument cluster doesn't lit .Otherwise the cruise control works just fine . Is it possible to fix this problem ? |
#18 | |
Yaris Hybrid Limited 2015
If its the basic one without RPM meter it probably also dont have the cruise light. Then you can switch it to one of these which should have cruise lights, my car has it. https://www.ebay.de/itm/Toyota-Yaris...p809:rk:2:pf:0 https://www.ebay.de/itm/Toyota-Yaris...UTE:rk:36:pf:0 https://www.ebay.de/itm/Tacho-Kombii...MAAOSwyWlbpqhd
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 Last edited by stykerdk; 12-05-2018 at 02:03 PM. |
| Tags |
| cruise control. 2012 |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
