Drives: 2007 Yaris Sedan Join Date: Nov 2011
My stock battery from my '07 died on Sunday - replaced it with the less expensive battery from autozone - the battery appears shorter than the original causing a problem with the rods that secure the battery with the engine hood holder ... any suggestions ?
You could go to HD or Lowes and get some threaded rod of the appropriate diameter, cut to fit, get a couple of the right size washers and nuts and make your own. What I'd do in a pinch. Don't use that piece anymore, have it in a box somewhere.
Stick something under the battery to raise it up a bit. I put a redtop in mine and it came with a plastic spacer to raise the height.
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| Toyota Yaris Battery Light On - Repair | gabo | General Yaris / Vitz Discussion | 1 | 08-24-2011 07:21 AM |
| Charging voltage for stock battery | Vinceb | DIY / Maintenance / Service | 3 | 02-12-2011 12:10 AM |
| Installation of a Battery Isolator | frostbitten | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-07-2009 12:11 PM |
