Old 03-10-2007, 07:34 PM   #1
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
Anyone seen the VentureOne?
This thing looks pretty awesome.
Introducing the VentureOne, a revolutionary 3-wheel, tilting, plug-in Hybrid vehicle. This unique 2-passenger flex-fuel Hybrid vehicle will achieve 100 miles per gallon with a top speed of over 100 mph.
And if that weren’t enough, imagine combining the performance feel of a sports car with the agility of a motorcycle. This is an exhilarating driving experience that can only be compared to flying a jet fighter two feet off the ground.
The VentureOne is a fully enclosed vehicle that is surrounded by a steel “safety cell” and other safety features typically found only in cars—things like side impact beams, driver airbag, rear bumper and engine shield.
While the same height and length as the MINI Cooper, the driver in the VentureOne sits as high off the road as a standard automobile. When combined with its 360° glass canopy effect, the VentureOne not only provides a driver with tremendous road visibility, but adds to a sense of overall driving confidence.
The VentureOne is a revolutionary new vision in transportation.
The VentureOne weighs approximately 1,200 pounds in prototype form, with an overall width of 48 inches, a length of 11' 8", and a 106 inch wheelbase. The engine is located in the rear of the vehicle at a low height. The passenger compartment and the front wheel tilt when cornering; however, the forces are aligned with the vertical axis of the driver’s body, resulting in the driver being pressed into the seat rather than pushed across it.
Although classified as a motorcycle according to the NHTSA (since it has three wheels), the VentureOne has an enclosed body. The reinforced roll-cage construction in combination with front-and-side-impact protection, and a highly efficient passenger restraint system, give the occupants a level of protection comparable to conventional cars — or statistically, 33 times the safety of a typical motorcycle.
Venture Vehicles plans to initially offer two propulsion packages for the VentureOne: the hybrid E50 and Q100, and all-electric Venture EV mode – with a wide range of accessories available for each.
All three classes will incorporate the patented Dynamic Vehicle Control system, or DVC™, developed by Carver Engineering, which allows the vehicle to tilt up to 45° side-to-side at a rate of 85° per second. All three will also feature ventilated disc brakes and measure 3.5 meters in overall length.
The vehicles’ propulsion system is of a series hybrid design. The system consists of a small internal combustion engine connected to a 15 – 20 kW generator, two in-wheel 25 kW electric motors, a four gallon fuel tank, and a 3 kWh Li-Ion battery pack. The system is able to take energy normally lost as heat due to braking and return it to the battery, increasing overall system efficiency.
All three models will exceed 100mpg, with speeds of over 100 mph, and breathtaking acceleration – a major breakthrough in the automotive industry.
More info and videos of the European version at the companies website.
http://www.flytheroad.com/
Dragonacc is offline   Reply With Quote
Old 03-10-2007, 07:42 PM   #2
Dragonacc
Prices are supposed to range from $20,000 - $23,000. Estimated availability is sometime in 2008.
The 100kw hybrid version is supposed to do 0-60 in under 5 seconds.
This would make an amazing replacement for my LB in a couple years.
Old 03-10-2007, 09:20 PM   #3
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Holy Shit that's cool!
Nutzoids is offline   Reply With Quote
Old 03-11-2007, 03:00 AM   #4
ChinoCharles
Drives: LB
Ridiculous.
Old 03-11-2007, 03:24 AM   #5
Slummy
Slummy's Avatar
Drives: Black LB
One question, how do those people fit in there?
I mean is it some kind of magic cabin, where it gets
bigger when you get inside?
Slummy is offline   Reply With Quote
Old 03-11-2007, 03:30 AM   #6
well you can clearly see the guy in the back has no legs, I think it is a requirement....
Old 03-11-2007, 03:41 AM   #7
Slummy
Slummy's Avatar
Drives: Black LB
well all in all, its pretty cool, but i'm not a big fan of the side window. its reminicent of the Subaru svx.
Old 03-11-2007, 10:02 AM   #8
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Think I'll save for the Atom instead....
jdubau55 is offline   Reply With Quote
Old 03-11-2007, 10:54 AM   #9
Hmmmm Ariel Atom... making the Lotus Elise seem like a truck...
Old 03-11-2007, 11:20 AM   #10
ChinoCharles
Drives: LB
I'd still rather have a Yamaha YZF R6.
Old 03-11-2007, 03:27 PM   #11
Dragonacc
You'd have to save twice as much, but to each his own.
Old 03-11-2007, 05:52 PM   #12
jdubau55
Twice yes, but about 4 times the fun factor. If I wanted to sway back and forth I can do that in my seat.
Old 03-11-2007, 05:59 PM   #13
Dragonacc
4 times the fun factor? How do you quantify that exactly?
Old 03-11-2007, 06:02 PM   #14
jdubau55
The Atom is much much faster. Both in a straight line and in the twisties. That, and its my humble opinion.
Old 03-11-2007, 07:46 PM   #15
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Guess road heads outta the question with this thing...
Old 03-11-2007, 08:00 PM   #16
Dragonacc
Road head?
The windows go down and the back of the roof comes off.
Maybe I'm not getting your meaning...?
Old 03-11-2007, 10:09 PM   #17
jdubau55
Def not getting his meaning.... picture guy driving car....girlfriend in passenger seat leaned over into his lap....
Old 03-11-2007, 10:13 PM   #18
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
lmao!
-- Blen
