Old 11-22-2011, 02:44 PM   #1
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
Originally Posted by A-Dingo-Ate-My-Baby View Post
figured out the rear Trico exact fit problem:
The Trico exact-fit replica wiper blade housing is close, but not exactly the same
as the OEM. The length stop-to-stop is 3mm longer. The Trico insert has some
wiggle room side-to-side, allowing the far-end of the insert to float off the glass
when pressure is applied to the middle of the insert
I slid the Trico insert out of the Trico arm, installed the Toyota arm, and slid in the
Trico insert. The Toyota stop tabs touch the insert at both ends of the blade, and when
the arm is at rest position, the stops hold the insert and keep it from floating off the glass.
So, in the case of: should I get a new insert, or a whole new Trico exact fit assembly ?
say NO to Trico, or just get the insert.
Other companies may make a better OEM-fit blade housing, but Trico dropped the ball on this one.
I now have 100% rear wiper contact. crisis averted.
may ask why not buy the toyota blade? doesn't seem expensive and you can replace the just rubber after.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 11-22-2011, 03:22 PM   #2
A-Dingo-Ate-My-Baby
Drives: yaris
I was on a mission to buy bundles of blades as presents
for everyone (dropped 380 bucks) and I figured I would also
try a trico exact fit.
This is my time to test a new batch of blades
[Just got done testing Michelins, RainXbrand, and Tripledge last 3 years]
so I went with Trico NeoForm on my Yaris, Trico exact fit (not so exact) rear.
and AquaPel as a surface coating (RainX only on side and back windows)
PIAA silicones on my 4runner and OEM rear insert, with RainX
and Silblade silicone for my GF, and sister gets PIAA's, with RainX
these silicone blades are not cheap
and I do not want to test AquaPel with Silicone blades. I need to test
with old-school Trico blades to know what Aquapel really does or does not do
this winter
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-02-2011, 08:29 PM   #3
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
this winter
You tried all those brands you listed over the last three years (is that how I should read that statement?)
If so, I take it none of them lived up to your expectations? Hence your high regard for trico?
Old 12-03-2011, 01:45 AM   #4
Perpetuous_Dreamer
Drives: Yaris 2007
A little advice: don't buy wiper blades from NAPA!!! They are the worst investment in my car I ever made. Threw them in garbage next day due to the loss of receipt and went back to Toyota's OEM ones.
Perpetuous_Dreamer is offline   Reply With Quote
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Wiper Blades futdechenes General Yaris / Vitz Discussion 44 06-27-2010 11:08 AM
What kind of wiper blades? buyah123 DIY / Maintenance / Service 9 11-25-2008 05:25 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
