Will work for Yaris...
Drives: Yaris Join Date: Feb 2006
FCC ID etc info
Guys I've read several threads about getting a new remote for the Yaris and having no luck...
Since Australia Yaris model all have transponder etc means we have to get either the genuine from the dealer (god forbid) or off ebay... I looked high and low in the Owners Manual and couldnt find the nessessary FCC ID and the other info regarding the remote and also pop over my now sticky tape covered remote and the only thing I found is the S/N on in the remote... Anyone give me a hand please...?
If you pop the left C pillar cover, the receiver is located underneath it and it should have the FCC ID on it or in a worst case, the Toyota part number, which can be referenced to an FCC ID.
Ok, would it be the same if I go to the dealer and ask for it...?
I checked on Ebay that the current Yaris remote there are different to my soft rubber cover which ofcoz not as durable as the current ones... Just worry getting the wrong one and wasted money and not being able to start the car... :) |
B789
Drives: Toyota Yaris Join Date: Dec 2009
FCC-ID MOZB41TG
![]() ![]() ![]() Drives: Yaris Join Date: Nov 2008
Will be best to go to toyota and give them your vin number and they will match up the correct remote for you. It wont be cheap though.
If possible you can find maybe a wrecked yaris from the same year and you can use that key from it and add your cars transponder code to it. You may have to erase all the transponder codes from all your keys. In the US workshop manuals they have a procedure on how to code your remote and transponder. |
Here is what i did... i hacked the original remote, made a incision to cut out the transponder and basically moved the remote module and transponder to a aftermarket key...
all done and it cost me less than 20 AUD... (including key cut...) |
| FCC ID for 2006 Toyota Yaris RS keyless Remote | canadian_gal | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 12-21-2010 06:47 PM |
| '10 4 dr LB speaker wiring routing info? | formulation | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 10-23-2010 11:24 AM |
| $1,600 Government Rebate on Fatt Batt Insulation or Solar Hot Water Systems Info. | *MAD DOG* | Australia | 1 | 03-27-2009 10:44 AM |
| how do i find the FCC ID for keyless entry? | worthit | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 11-15-2008 10:28 PM |
| bi-xenon info | Adriaan | Cosmetic Modifications (Exterior/Interior) | 0 | 02-05-2007 07:21 PM |
