I havent put a double din in but from what I get you pull out the stock unit. Rape it of the bracket on the side. Bolt that to the new double din HU then bolt it back in. You will have a lil bit of gap on the sides but I think the top to bottom is spot on. Someone correct\verify me though.
#2 | |
![]() ![]() Drives: 07 Yaris Hatch 5speed Join Date: Nov 2006
Reuse the stock bracket, which you have even if you have the radio delete cover. I found that the stock bracket had "bumps" on the inside so I used an angle grinder to sand them off. There will be gaps on both sides, but if you had the radio deleted, then you probably have a black plastic cover for the empty hole. What I did was take the plastic cover, and cut the sides off with a hacksaw, then glued them on the inside of the radio surround panel. It isn't perfect, but it was free and no more gap. Also, the stock bracket is much stronger than the plastic shit from Scosche. We had one of their kits in our Echo, and we were rear ended.(it was written off) The deck popped out on impact. Good thing I didn't have the screen out! Last edited by earljail; 03-13-2007 at 09:47 AM. Reason: Added info about aftermarket brackets. |
Here- the first pic is how large the gaps will be. Yes, I know that the trim piece is upside down.
The second one is with the "hole-fillers" I custom made for $0. |
| Dash Kit - No Mods | barryware | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 09-14-2014 03:59 PM |
| Is aftermarket HID kit legal (in NJ)? | Jfoofoo | Cosmetic Modifications (Exterior/Interior) | 25 | 03-19-2009 02:05 PM |
| Dash Kit if interested....ebay | fnkngrv | Cosmetic Modifications (Exterior/Interior) | 0 | 07-03-2006 10:18 AM |
