How'd you wire them up? Mine are as bright as the LEDs when the lights are off, but when they are on it pretty much washes them out (I drove down to a local empty strip mall so I could see how they looked in the window reflection). But with the lights off, both the halos and LEDs are bright as hell...
Also, how'd you get such a good pic? Cheers! M2
Same here, when the lights are on, the halos are as good as invisible.
![]() But I changed some things now (well, I didn't do it myself). Now I use the LEDs as DRL and as soon as I turn on the lights, the LEDs go out. It just didn't look right when the white/blue LEDs and the "yellow" lights were on together. I changed the bulbs to brighter ones, but it's still not the same. And HID wasn't an option for me. Oh, and what do you mean with a good pic? It's just an average pic like any other?
#3 | |
As for the pic, the LEDs were just too bright for me to get a good pic. Maybe I need to play with the settings on my camera and try again when there's still some daylight left instead of at night light I did. Cheers! M2
Verbieten Sie
Yeah, my halos are also the yellow-ish color.
My halos are as white as the LEDs, it's the lights themselves (high and low beams) that are yellow.
I guess these are H1 bulbs (I didn't check to see), any suggestions on a whiter bulb that won't melt anything? Cheers! M2
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: May 2007
and these are bright enough to see the road well at night? I really wanted these but read a lot of comments on here about them not being bright enough without HID and something about the halo lights going out a lot
#7 | |
I only test drove these last night and my eyesight in the dark isn't as good as it once was, but they are not an improvement. The beam width is narrower, and while the low beams are bright, they don't seem to project as well as the stock ones did. I think it has to do with the design, I don't know the scientific explanation for it but the dome lens on the low beam seems to send the light in all directions not direct it forward like the high beams do. Still, I am happy with them, I don't do a lot of nighttime driving and when I do it's in lit areas or at slower speeds in the more rural parts. But the bottom line is that if you're looking for an improvement in lighting from these units, you won't get it in stock form. I think HID upgrades would be a better option in that regard... Cheers! M2
Here's a pic from work this morning, taken just as the sun was rising and with the LEDs/halos on...
![]() And just a few other "glamour" shots... ![]() ![]() Needless to say I'm chuffed about them! ![]() Cheers! M2
OK, got some pics this evening with just the LEDs and halos on to show how bright they are...
![]() ![]() ![]() Now, has anyone figured out how to adjust these bad boys? The low beams seem to be aimed high, I would like to lower them a bit to get the main part of the beam more down to the road... Cheers! M2
Not quite a noob
The right side of the cutoff kicks up I think, there's no way to avoid it shooting high on the right. You adjust it with the sprocket looking thing just to the inside of the high beam. It should be copper/bronze in colour. I think clockwise is down, and counter is up. You can either see if you can see the direction on the knob itself, or just do it by experimentation against a wall with the lights on.
Thanks, I see that knob but was thinking it was only for the high beams. Does it adjust both?
I'm thinking headlamps are next on my list... @MadMax, how are your headlamps holding up so far?
#13 | |
Cheers! M2
![]() ![]() Drives: 2011 Toyota Yaris Join Date: Jan 2011
Just my opinion, but I think that running 5000K HIDs in the stock reflector lenses throws out more light then those projector lenses. I do alot of nighttime driving usually where there are no street lights, and the HIDs just seem to throw out more light in all directions then those expensive after-market projector lenses. We tend to have alot of deer grazing on sides of the road sometimes, along with drunks walking home at night who wear all black clothes or teens that think it's cool to walk in the middle of the road and play chicken, and the extra light thrown off to the sides helps me a bunch when there are no street lights. The projectors definitely look cool, but I'm all about the light output!
#15 | |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
I'm with you with hids on stock headlights , since I live in backwoods suburbs.. But it's blinding the other driver from the opposite direction .even on a lowered car, I still have people flashing me occasionally .... |
![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
I like to see them on the hatch, not so much the sedan.
Form>Function
agreed, I want a retrofit for mine.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
I run 6000K HID's in stock housings, aimed down. Light output is great, and I do not blind oncoming traffic.
| eBay Issue - Your help needed | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 02-04-2011 09:18 PM |
| WTB: Gauge Cluster w/tach for HB | cdydjded | Willing to Buy by private party | 12 | 06-09-2010 03:49 PM |
| Cheap eBay LED Strip vs V-LED Strip | Kaotic Lazagna | Cosmetic Modifications (Exterior/Interior) | 1 | 03-18-2010 08:06 PM |
| Pre Hack Revival: Megan Racing Header vs Ebay Header | Sabretooth | Performance Modifications | 15 | 08-19-2009 05:26 PM |
| ebay intake: would you? | thebarber | Performance Modifications | 7 | 12-03-2008 12:44 AM |
