Old 12-01-2011, 03:59 AM   #1
matthewai
matthewai's Avatar
Drives: it is kinda stock
i have stock steelies and just went from a 185/60 to 195/55 i dont think it throws off the speedo and its a subtle difference look wise but you can kinda tell its a little wider obvi. but feel wise it seems alot more stable and better grip when taking turns in my opinion, overall im happy. i also have 19mm rear sway bar and mi springs
Old 12-01-2011, 08:25 AM   #2
A-Dingo-Ate-My-Baby
Drives: yaris
your speedo will read 1.2 percent too fast on 195/55 vs 185/60
actual speed 59.3 speedo reads 60
http://www.tacomaworld.com/forum/tirecalc.php
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-01-2011, 10:41 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
(QUOTE=A-Dingo-Ate-My-Baby;616875]your speedo will read 1.2 percent too fast on 195/55 vs 185/60
actual speed 59.3 speedo reads 60)
This would be true if the speedo were acurate out of the box with the 185/60/15's... but it isn't.
I went from 185/60/15's to 205/50/16's (1.5% taller) and now my speedo is dead on!
Anyway, if you don't plan to drop the car, I would recommend replacing the 185/60's with 195/60's (2% taller) or 205/55's (0.7% taller). They'll fit the stock steel wheels comfortably and safely.
Question about tire size with TRD drop. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 01-29-2009 05:30 PM
Tire Size Question Yaristwn Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 01-29-2009 01:28 PM
Tire Size Question ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 10-30-2008 12:53 AM
noob question about stock tires xCookiE Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 06-19-2007 08:40 AM
