#1 | |
So, the issue is seriously mismatched wire sizes for the tap splices. Since the car side is the important side, I actually use the tap splices sized for the car's wires (which are the red ones {24-18 AWG}). When you crimp them onto the small gauge car wire and large gauge remote starter wires, some of the strands of the remote starter wire will get cut off, but what remains will be at least the same gauge as the car wire. I do use the Scotchlok ones and find them to be better quality than many of the other brands.
#2 | |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
So I finally did get the Scotchlok connectors as well as my remote start but I am having some issues getting it going. This is a Viper 4203v unit (Responder One): Starter wires -> car wires Pink Ignition -> Green ignition Pink/White Secondary ignition -> Pink ignition Purple Starter -> Black starter Orange Accessory -> White accessory Red 12v - 12v on fuse panel (top) Red 12v - 12v on fuse panel (top) Black/White Neutral Switch -> to ground Violet/White Tach wire -> L.Green on OBD2 Brown brake -> Green brake +12 Grey hoodswitch -> not connected Everything looks like it is connected properly, but it seems the unit will not turn on. I would think if the unit was powering up I would see the red LED come on for at least a second but it does not. I have checked my connections with a multi-meter and everything looks good. Is there something I am missing here? I have never installed a remote start before and reading through this thread made me think it was easy, lol. |
#3 | |
I don't have the manual for the 4203v, but what you are connected to looks good. Check the install manual for a start-up or configuration process that may have to be done before it will work.
The only thing I can see that I didn't do is the 'tach learning' ... I'm going to try that and see if it works.
#5 | |
I am wondering if the hood safety switch needs to be connected to ground for the unit to operate. They don't really explain in the manual except saying it NEEDS to be connected (I've read you don't have to connect it but I guess it's worth a try). |
#6 | |
![]() Drives: 09 Yaris Sedan Flint Mica Join Date: May 2009
Just got new unit
Hi everyone this is my first post in a long time >:D i'm getting ready to install the ultrastart u4296m next week while i'm on vacation! my only question is about the clutch. will i have to bypass the switch to remote start, if so how do i. thanks yarisworld and Scott for all the great information.
*Update* Hi everyone well i was a fool. Looks like i missed the clutch relay pic in post #118 first time around lol got a relay and everything works awesome. Thanks again YW!! i love this site Last edited by NHYarisFan; 01-01-2012 at 11:38 PM. |
#8 | |
I'm going to verify my ground point ... that's the only other thing I can think of. |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 02:32 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 02:26 AM |
