Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 12-04-2011, 03:21 AM   #37
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Originally Posted by syntax View Post
@ rye naobserbahan mo na ba kapag CAI, kapag 3rd gear ano ung speed mo kapag nasa 4K ang RPM mo?
100kph
try mo..
rye7jen is offline   Reply With Quote
Old 12-04-2011, 03:31 AM   #38
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Lalo na pag segunda, unti-untiin mong tapakan yung throttle hanggang umabot sa 4k rpm sabay pasok sa tresera... hehehehehehe!
Old 12-04-2011, 04:30 AM   #39
syntax
syntax's Avatar
Originally Posted by rye7jen View Post
100kph
try mo..
nyahahahhaha sabi ko na nga ba eh, hindi talaga maiwasan ung ihataw noh? tsalap tsalap wehehehe
Old 12-04-2011, 04:34 AM   #40
syntax
syntax's Avatar
yep midrange to upper rpm talaga ang CAI, subukan nyo SRI vs CAI sa arangkada...
Old 12-04-2011, 07:47 AM   #41
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Tol na-try ko na yung kay Gian at iba talaga arangkada niya, naka-CAI din siya before... yung iyo diko pa natry eh,, we'll see,, heheehe!!
Old 12-04-2011, 07:58 AM   #42
syntax
syntax's Avatar
nyahahahhaha cge cge set natin yan wehehehe
Old 03-11-2012, 01:30 PM   #43
amaze_2
amaze_2's Avatar
Drives: 2008 yaris
C, YES- bolt-on to 1.3L 2nz yaris. ganyan na ganyan yung intake kit ko dati at namana na ngayon ni blessed yaris. Nasa $200+ pa nun ang bili ko from ebay. Ang advantage nito is easy to fit and easy to remove as the design is plug and play.
Kung locally made naman or diy, maraming options..either via PVC tee pipe mod (like exweber/syntax) or via coupling with aluminum tube using the OE MAF mount. I prefer na you score OE maf mount + tube from a junk yaris. Keeping your original behind the trunk and you can put it back during rainy days or sandstorm season.
HiH
@ricepower ito ba ang disadvantage ng CAI setup dapat lagi maganda ang weather?di pwede sa sandstorm eh dito sa saudi laging sandstorm.wala bang CIA na kahit sandstorm and rainy season wala maging problema?
amaze_2 is offline   Reply With Quote
Old 03-14-2012, 12:02 AM   #44
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
@Amaze, look forward sa advantage. Kung ang concern mo is yung sandstorm, may DIY dyan. Either balutin mo ng foam yung air intake (e.g ung ginagamit sa window AC) or lagyan mo ng shield during sandstorm.
ricepower is offline   Reply With Quote
Old 03-14-2012, 03:52 AM   #45
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
+1
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 03-18-2012, 06:41 AM   #46
syntax
syntax's Avatar
tulad ngayon sandstorm na naman, if may time kayo mga kayaris, linisin na agad ang air filter dahil for sure kapal ng buhangin nyan.
Old 03-18-2012, 11:24 AM   #47
duke_afterdeath
tol ung filter ko dalawang sandstorm na pinagdaanan diko pa nalilinis, hehehe...
Old 03-18-2012, 03:45 PM   #48
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Tol dalawa pa lang ba bilang mo??? he he he
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 03-20-2012, 05:35 AM   #49
duke_afterdeath
I mean dalawang heavy sandstorm, hindi pa kasali kung ilang araw ang duration bawat isa, hehehe...
Old 03-24-2012, 12:59 AM   #50
syntax
syntax's Avatar
heheheheh nakita mo naman ang resulta kahapon diba duke? nyahahahaha
Old 03-24-2012, 05:41 AM   #51
duke_afterdeath
uu nga tol, now clean n green nanaman si storm, hehehe.. plus new spark plugs at ok na ung brakes, smooth nanaman takbo ni storm
Old 03-24-2012, 07:41 AM   #52
syntax
syntax's Avatar
hehehehe, isang timba ata ng buhangin si storm, ung red na at black na engine bay, naging orange wehehehehe
ok na brakes pre? wala naman ako narinig nung tinetesting diba?
Old 04-09-2012, 06:49 AM   #53
Onads
Onads's Avatar
Drives: Vios/Yaris
Yan lang ang disadvantage ng open filter. Why not try the drop in filter ng K&N paps? I think same performance with a stock look. kasi ma retain mo ung box ng filter mo (protection unwanted materials ) pero naka aftermarket filter ka.
Question lang: meron ba dito nag customize ng headers and pipings for Yaris?
thanks
Onads is offline   Reply With Quote
Old 04-09-2012, 07:51 AM   #54
syntax
syntax's Avatar
thanks
ganun talaga ang may mga mods papi, there is always a price to pay.. kapag sa intake be ready to clean regularly. and galing ako sa K&N drop in filter, iba ang hatak ng SRI or CAI compared sa OEM box with drop in K&N drop in filter
sa question mo sa headers and pipings, wala nito sa riyadhor sa east, (dammam,khobar) naghahanap din kami nyan dati.
Any Aftermarket Intakes Yet?!?!?!?! silverRS Performance Modifications 120 12-07-2011 06:44 PM
Weapon-r sheet metal intakes 1/2 off (almost) H3LlIoN Forced Induction Forum 5 11-27-2010 12:21 AM
aFe intakes in stock! cali yaris Micro Image 66 02-11-2010 04:58 PM
air intakes? SLIK4 General Yaris / Vitz Discussion 16 05-21-2007 09:34 PM
