Old 12-04-2011, 09:24 AM   #1
enviri
enviri's Avatar
Drives: 2010 Yaris
I had the same issue. i had to do something drastic and made sure there's no air leaking through the maf hole. I REALLY dont recommend it, but i had a few mafs in my house and used sealant.
I loved the intake design, except for that one stupid maf mounting flaw. Also check if the metal cylinder part where you screw into isn't loose or coming out of the molded plastic. if it is, epoxy or superglue that cylinder in.
Old 12-11-2011, 10:08 PM   #2
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
Which metal cylinder part do you mean?
This problem happens most when I have cruise control on and I'm going uphill at anywhere from 45 to 65 mpg.
33.7 mpg in PA
bad is offline   Reply With Quote
Old 03-16-2012, 10:59 PM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
the metal cylinder is covered by the black plastic. its where the screw goes in when you mount the maf.
Tags
afe power cold air intake, air filter, air intake, check engine light, mpg
Check Engine and Traction Control Light On limey163 DIY / Maintenance / Service 21 07-14-2013 03:03 PM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
AFE cai intake....pros/cons severous01 Performance Modifications 21 06-30-2009 02:55 AM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
