Old 12-09-2011, 12:51 PM   #11
motoman740
Drives: 2012 yaris 3 door
Indeed. the tricky thing is just figuring out the airbag removal, as it is different from the 2nd gen Yaris, with the clips instead of screws.
With the light piece that you mentioned above, I think you meant SRS, not ABS light. But, if you disconnect and reconnect the airbag connectors with the battery disconnected the SRS will not log a DTC and turn the light on. If you were to do it with power, or connect the battery to test the cruise before reconnecting the airbag, then you would get the SRS light.
Good to know.
Also, I was looking at the steering wheel yesterday and I think the clips just hold it in place, and all you need to do is pull the thing straight out.
motoman740 is offline   Reply With Quote
cruise control. 2012
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
