Old 12-09-2011, 03:01 PM   #1
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
Any momentary switch is fine. You are switching an analog input to a microcontroller, so the current is negligible.
For the resistors the tolerance means how far they can be off, so a 100 ohm, 5% can be 95 to 105 ohms. Since it is a plus or minus rating, chaining them together means that they can cancel each other out, or add to the percentage off in either direction. If you have a multimeter, you can measure the actual resistance of each.
thx for the quick reply. what then would be the permitted resistance ratings to get this to work? I plan on just using 2 switches, listed is 240 and 390-- how close should i be to that?
Old 12-09-2011, 03:10 PM   #2
scape
scape's Avatar
actually looking back at the wiring for two buttons, one single resistor of 630ohm seems like it would work-- between the two buttons on positive; still not sure about the set-cc pushbutton resistances range though
Old 12-09-2011, 03:11 PM   #3
You can use any value within these ranges:
216 to 264 ohms for one between resume and on/off
351 to 426 ohms for the one between set and resume
819 to 1001 ohms for the one between set and cancel
For the two button method, a single resistor 567 to 690 ohms can replace the 240 and 390 ohm resistors.
For current rating of the resistors, like the switches, it really doesn't matter, so 1/8 W, 1/4 W, 1/2 W, etc. are all fine.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
