Old 12-10-2011, 10:17 PM   #1
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
you can always swap in the se steering rack! that's gives you the quicker ratios and better feel, and you could probably keep the same power assist as the base.
Originally Posted by StrangeRanger View Post
The SE doesn't come as a 3-door and it comes with too much in the way of "features" that I dislike. The chief appeals of the L are the lack of rear doors and its stripped down content.
Totally manual doesn't bother me in the slightest. I really don't see why a 2200# car even needs power assist. I have driven many in that weight range that were not assisted and had no issues.
If you pull the fuse, are you still fighting against the electrical assist, increasing the effort sort of like a hydraulic assist with a bypassed pulley? Or does the electrical system just go into neutral?
Is the assist from an SE retro-fittable to an L? That might be the easiest although certainly not the least expensive fix. The boneyards aren't exactly full of Yaris SEs
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Is this normal with the Yaris steering lock? STC General Yaris / Vitz Discussion 13 07-06-2010 10:15 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
Steering Wheel Spacers? BassAssassin Cosmetic Modifications (Exterior/Interior) 0 08-12-2009 12:52 PM
