Old 12-12-2011, 08:19 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Awesome video Xa ! What turbo and boost is yours running?
Parmas is offline   Reply With Quote
Old 12-12-2011, 07:08 PM   #2
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Garrett t3 60 trim, 27psi. My fastest 1/4 mile ET was on 23psi ( track was ridiculously well prepped).
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 12-14-2011, 03:19 AM   #3
Parmas
Parmas's Avatar
Wow 27 psi on a yaris, I suppose you are near 400Hp! Are you running/mixing racing fuel and methanol aswell ?
What's your fastest 1/4 mile ?
Old 12-14-2011, 06:33 PM   #4
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
93 octane pump gas, with water methanol injection ( peak windshield washer fluid). 12.29 was my quickest ET, once tracks open again after the winter I will run full boost on that same track.
Ptuning.com
Old 12-15-2011, 12:56 AM   #5
Parmas
Parmas's Avatar
Don't you think running high boost on low octane can cause detonation and damage your motor? What is your maximum ignition timing presently?
Old 12-19-2011, 10:17 AM   #6
Parmas
Parmas's Avatar
Im confused here..... are you using water or methanol mixture or else ?
This applies to garm aswell...
