Old 12-13-2011, 05:17 PM   #1
NightOwl84
Drives: Yaris Hatch
Engine Mods???
I'm looking for a website where I can get a stroker kit and to find cams?
NightOwl84 is offline   Reply With Quote
Old 12-13-2011, 05:57 PM   #2
Microimageonline.com
If he doesn't have it in the store, he can likely get it
Old 12-13-2011, 06:42 PM   #3
email us. sales.microimage@gmail.com
(thanks barber )
Old 12-13-2011, 07:34 PM   #4
TURBO YARIS
Drives: Yaris
No one makes a stroker kit for the 1NZ, Jun makes cams. May I ask what is you goal? There are many other options to make more power. Also keep in mind that you are going to need some deep pockets for the above parts.
TURBO YARIS is offline   Reply With Quote
Old 12-13-2011, 11:12 PM   #5
Web and one other company also make cams. But unless they are part of an extreme build, they don't make a bit of power.
Old 12-14-2011, 03:59 AM   #6
NightOwl84
Drives: Yaris Hatch
I'm trying to built a nasty road racer but I also was to use it as a daily driver. I was just wondering if they make a stroker kit
Old 12-14-2011, 09:44 AM   #7
TURBO YARIS
Drives: Yaris
If you do not want to go with a S/C or turbo do a motor swap. The 1.8 from the xD is the closest you will find to a direct bolt in. All other possible engines will require alot of custom fabrication and rewiring.
Old 12-14-2011, 11:48 AM   #8
NightOwl, read a lot more on here. It's clear you don't know the Yaris very well (no disrespect intended), and more information would help you a lot in designing your build.
You can always call our shop at (818) 610-3635. I can help you with options and budgeting.
Making the Yaris into a nasty road racer is a challenge, but do-able. A motor swap is probably not the easiest way to achieve that goal.
Old 12-14-2011, 03:31 PM   #9
ttr125fan09
ttr125fan09's Avatar
Drives: yaris
toyboxracingstore.com has a stroker kit, but it expensive
ttr125fan09 is offline   Reply With Quote
Old 12-14-2011, 06:00 PM   #10
TURBO YARIS
Drives: Yaris
I stand corrected. $4500 is steep & you get what you pay for. IMO start with suspension mods & bolt ons if you are not going the boosted route. BTW you can build a hell of a custom turbokit for $4500 & have better results than a stroker kit.
Old 12-14-2011, 03:34 PM   #11
ttr125fan09
Drives: yaris
heres a link http://www.toyboxracingstore.com/engine.html
Old 12-14-2011, 05:09 PM   #12
$4500 is a joke. Half those parts do nothing to make power.
Old 12-14-2011, 08:18 PM   #13
ttr125fan09
Drives: yaris
yes 4500 is ridiculous, but until he has competition the price isn't going down..
Old 02-18-2012, 04:11 PM   #14
10 Francis
Drives: 2010 Yaris S HB
Don't get too excited, Night Owl. ttr, those parts are for a 1NR-FE. USDM Yaris use the 1NZ-FE.
Unless there's something I'm not seeing on that site.
10 Francis is offline   Reply With Quote
Old 02-18-2012, 09:24 PM   #15
^ Golden Eagle, within driving distance of us. I can go pick up one of those for you.
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
2ZR-FE mods 2ZR-FE Performance Modifications 5 04-06-2011 04:22 PM
2ZR-FE mods 2ZR-FE Yaris TS Talk 9 02-09-2011 01:10 PM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
