Old 12-14-2011, 03:56 AM   #1
syntax
syntax's Avatar
Originally Posted by ricepower View Post
OLD P/N : 87103-52140
NEW P/N : 87103-52141
I suggest that you just buy a used from the local scrapyard preferably from a 2011 model. New one from Dealer will cost you around ~$250
I tried to repair mine before by dismantling the motor and the fan unit but with worse result. I damaged the bushing assembly of the motor. The problem is that the motor bushing is is not a ball bearing type and just only plain brass bushing which will get loose especially when out of grease/lubricant.
HiH
+ 1 the local scrapyard should have alot of this...
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C blower resistor ubear7 DIY / Maintenance / Service 1 08-08-2010 09:53 PM
A/c blower motor noise!!!! LBdriver General Yaris / Vitz Discussion 28 09-12-2007 07:46 AM
A/C blower flighttekchris DIY / Maintenance / Service 5 08-25-2007 11:42 AM
