Old 12-20-2011, 04:40 PM   #1
bronsin
bronsin's Avatar
Ah thanks! I have a couple days off and nothing to do!
The chart for the resistance values for testing the switch is the same.
Does the cool engine light go out when you press the momentary switch?
Old 12-20-2011, 05:28 PM   #2
Yes. If you hold the switch for about two seconds the light will go out. About a second or two after you release it the cold light comes back on.
Tags
automatic, bypass, lock-up, prohibition, transmission
No 4th gear in A/T? caineroad General Yaris / Vitz Discussion 13 09-11-2009 06:47 PM
Cold Engine and Gear Shifting captainm27 General Yaris / Vitz Discussion 9 01-29-2009 08:27 AM
