Old 03-13-2007, 08:07 AM   #1
doginmyyaris
Drives: 07 yaris
Question install help!
Ran into trouble while installing my Secret Weapon intake.
Following the included instructions, #14 states to "install the rubber mounting grommet...to the bracket on intake pipe."
What "bracket" on intake pipe? I suppose I could have missed said bracket before installing the pipe and air cleaner, but nothing is visible post-install.
Without this bracket, the intake has *too* much give and will work itself loose!
doginmyyaris is offline   Reply With Quote
Old 03-13-2007, 11:03 AM   #2
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Take a look at the first post in this thread. The photo shows the items included in the kit. You should have everything there. To the best of my knowledge, and I own one of these intakes myself, there is no "bracket" or "grommet" on the intake pipe. You simply hook that universal bracket underneath one of the hose clamps and then bend it and attach it to the nearest mounting point. This will prevent the filter from bobbing around or working itself loose. I don't have a photo hand but I know my bracket is bolted to the front battery hold down. And you will have to bend the bracket. Let me know if you have any other questions.
Galavoxx is offline   Reply With Quote
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
