Old 12-31-2011, 10:31 PM   #1
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
I've put 60K miles on mine and still fine the engine to be very quiet compared to most other vehicles in it's class. I did find early on trying different motor oils seemed to increase engine noise-don't know why, it was just an experiment and that's what stuck out the most. The thing that still impresses me the most is how quiet the a/c compressor is-no loud click or hissing sounds under the dash as in some vehicles.
I did find the new chevy sonic and ford fiesta to be very quiet, but I believe it was mostly due to sound deadening in the firewall and not the engine being any better design. Neither the Yaris nor Honda Fit use a lot of sound deadening which saves on weight and cost, but adds noise when accelerating. Now that I think about it both the sonic non-turbo and fiesta use costly, pain in the butt timing belts and it's always been said they are quieter in operating than a timing chain as the Yaris has.
UTVitz is offline   Reply With Quote
Old 12-31-2011, 11:31 PM   #2
Gogogordy
Drives: Miss my Yaris, love my Jeep jk
Noise suppression is indeed one of oils' primary job duties. Also cleansing, cooling, and off course providing a microscopic barrier between mating surfaces.
Gogogordy is offline   Reply With Quote
Old 12-31-2011, 11:43 PM   #3
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
I actually find mine pretty quiet up to about 3K RPM (I once turned the ignition by accident when it was already idling). Also keep in mind that because it only outputs 106 horsepower at the crank, the gears are shorter. Go over 60 MPH and it's bound to scream a little.
Old 01-01-2012, 01:31 AM   #4
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
The Yaris has more engine noise than the echo (same engine).
The stock yaris intake is simpler than the echo intake. I think that is where most of the noise comes from.
Old 01-01-2012, 01:31 PM   #5
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
+1 on that, mine is pretty buzzy under load and it does sound like intake noise.
overall, yes, this engine is on the loud side. quiet when not loaded, but under any kind of load the noise is definitely starts to come through. I find that I have to adjust the radio volume more often than in other cars I had. But it's ok, it's not too bad.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 01-01-2012, 12:02 PM   #6
Hamster
Hamster's Avatar
Drives: 2009 5-Door Liftback
Anybody know which brand of oil is best at reducing noise? I'd like to try it out the next time I do an oil change.
Hamster is offline   Reply With Quote
2007 Toyota Yaris engine assembly dunetrooper Items for Sale by private party 14 07-10-2010 08:31 PM
Toyota Yaris Engine Map wariss Performance Modifications 5 03-15-2009 12:21 PM
Is the Yaris engine a little rough? thomasward00 General Yaris / Vitz Discussion 23 04-30-2007 12:17 PM
