Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Northwest
Old 01-05-2012, 11:27 AM   #1
Removing the vent hose is actually very easy. You push in on the clips and the pull the connector off of the metal pipe. That little black box that it connects to is the canister filter, so you may want to also check it for occlusion.
Also, there is a TSB for the 07 Yaris for an issue where the device that is supposed to prevent water from entering the evaporative system is faulty, resulting in the canister filling with water. This will cause the MIL to illuminate, which is doesn't sound like is happening with yours.
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Accurate fuel fill without topping off? sbergman27 Fuel Economy Forum 25 02-11-2012 03:58 PM
